SEB95-20 Nose gear actuator down lock pin inspection
R/TR182 Service Bulletins & Service Letters listed here
Has thanked: 9 times
Been thanked: 7 times
Important to review/understand the SB to prevent NLG collapse. 2nd attachment is real world example of NLG collapse due to not performing SEB95-20.
SEB95-20 NoseGear Actuator DownLock Pin Inspection.pdf
(158.44 KiB) Downloaded 175 times
CessnaRG NoseGear Collapse Example.pdf
(2.3 MiB) Downloaded 195 times
skybert
Has thanked: 1 time
Re: SEB95-20 Nose gear actuator down lock pin inspection
Post by skybert »
Any idea on a shop that’s done this and approximate cost?
In late 2020 Air Repair in Prescott, AZ performed SEB95-20 as part of our prebuy and cost was $1300, which is approximately 10 labor hours. Air Repair's mechanics had maintained R182s so were familiar with this SB, meaning other unfamiliar shops may take longer/cost more.
We borrowed the drill guide tool(PN1290009-3) to avoid the cost of SK210-155(approx.$3000) which kept the cost low by avoiding the cost of the Service Kit. We're working on sourcing of the drill guide or Service Kit for a reasonable cost for type club members.
View SEB95-20 here:
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 001.jpg (150.78 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 002.jpg (166.07 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 003.jpg (129.51 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 004.jpg (127.36 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 005.jpg (166.32 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 006.jpg (144.05 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 007.jpg (160.66 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 008.jpg (92.71 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 009.jpg (158.29 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 010.jpg (141.2 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 011.jpg (151.87 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 012.jpg (203.67 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 013.jpg (105.33 KiB) Viewed 2458 times
SEB95-20 NoseGear Actuator DownLock Pin Inspection Page 014.jpg (124.13 KiB) Viewed 2458 times
skybert
Has thanked: 1 time
Post by skybert »
A) did you send the part to them to have the mod done?
B) anyone in the Great Lakes are do this?
The shop supplied the new roll pins & downlock pins, and I sent them the borrowed drill tool.
The rolls pins are commodity items and at that time the downlock pins were in stock at Textron and inexpensive.
Any experienced Cessna shop shop be familiar with SEB95-20. I know of an individual mechanic here
in SE WI who is familiar with it as well.
See highlights & comments on p.3. If your airplane has not had SEB95-20 performed then
p.3 is key information. Keeping in mind the late model C210 NLG actuator assemblies
are identical to the R/TR182 - this is confirmed in the Effectivity list on P1&2 of the SB.
CessnaRG NoseGear Collapse Example Page 001.jpg (191.18 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 002.jpg (220.09 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 003.jpg (254.42 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 004.jpg (193.9 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 005.jpg (232.34 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 006.jpg (252.37 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 007.jpg (250.5 KiB) Viewed 242 times
CessnaRG NoseGear Collapse Example Page 008.jpg (190.16 KiB) Viewed 242 times
028tech Nose Gear Spring Guide & Actuator Pin Inspection.pdf
(232.61 KiB) Downloaded 47 times
(2.3 MiB) Downloaded 47 times
