R182 owner Bruce Wiley noticed fluid leakage at his MLG brake swivel fitting that turned out to be the actuator bushing working its way off of its shaft. He then worked with a machinist to produce a better than OEM part to replace the original. Inspecting this bushing's position should be included in your annual inspection of MLG actuators. Note the R/TR182 Parts Manual does not show this bushing on p.155, Fig. 56 per the below slides. Bruce Wiley explains this bushing replacement in detail at the 2/26/2025 Zoom call with McFarlane at https://www.youtube.com/watch?v=hc-_s8T1kHM&t=628s
Main Landing Gear(MLG) Actuator Bushing replacement
- Has thanked: 8 times
- Been thanked: 7 times
