Lycoming Mandatory Service Bulletin No. 388C; Procedure to Determine Exhaust Valve and Guide Condition; AKA Wobble Test
Posted: Fri Mar 28, 2025 2:01 am
Lycoming recommends this procedure every 400hrs for airplanes and every 300hrs for helicopters. The intent is to prevent exhaust valves from sticking 'i.e. morning sickness' by making sure the valve has ample clearance within the guide where exhaust residue can build up and can cause the valve to get stuck. Leaning in flight and on the ground can reduce the likeliness of a sticky valve.
Mechanics who are familiar and proficient with this test sometimes do an abbreviated version of it where they can tell by feel how far the valve moves side-to-side, saving much time.
Fixture tool info is attached as well.
This procedure is particularly useful for high time engines where valve sticking can be more likely.
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 001.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 001.jpg (209.25 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 002.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 002.jpg (196.68 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 003.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 003.jpg (152.33 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 004.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 004.jpg (153.3 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 005.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 005.jpg (197.66 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 006.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 006.jpg (243.46 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 007.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 007.jpg (191.66 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page [attachment=7]Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 008.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 009.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 009.jpg (201.35 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 010.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 010.jpg (199.35 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 011.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 011.jpg (213.44 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 012.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 012.jpg (113.98 KiB) Viewed 1589 times
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 013.jpg
Lycoming388CProcedureWobbleTest)20Determine20Value20Guide%20Condition Page 013.jpg (115.7 KiB) Viewed 1589 times
Valve Wobble Test Fixture _ Aircraft Spruce.jpg (72.21 KiB) Viewed 1589 times
