Air Power - Explanation of Cylinder Porting by Lycon
Posted: Sun Nov 16, 2025 4:32 pm
cylinder__porting Page 001.jpg (336.48 KiB) Viewed 151 times
cylinder__porting Page 002.jpg (307.17 KiB) Viewed 151 times
cylinder__porting Page 003.jpg (288.72 KiB) Viewed 151 times
cylinder__porting Page 004.jpg (337.53 KiB) Viewed 151 times
cylinder__porting Page 005.jpg (344.5 KiB) Viewed 151 times
cylinder__porting Page 006.jpg (304.48 KiB) Viewed 151 times
cylinder__porting Page 007.jpg (266.46 KiB) Viewed 151 times
cylinder__porting Page 008.jpg (381.56 KiB) Viewed 151 times
Re: Air Power - Explanation of Cylinder Porting by Lycon; Cost Information
Posted: Wed Jan 14, 2026 8:28 pm
Mike Pattison reported Ly-Con port & polish service for this IO-540-K1G5 as $350/cylinder, and total cost for overhaul of all six cylinders to be $2200 each.
Mike reports his airplane picked up 11kts of TAS in cruise flight after Ly-Con's cylinder overhaul/port&polish work.
That's alot of speed to pickup! See further performance information below.
Sent: Thursday, January 8, 2026 3:02 PM
To: scott@cessnar182.com
Subject: RE: Reminder - Tuesday 1/6/2026 7PM CST Zoom discussion with Cessna R/TR182 Type Club
Scott
We’d expect to see 25/30HP increase in the dyno with ported cylinders
And yes, there is an STC on our case o-ring mod…so okay for certified engines. We charge $1278.00 to modify the cases
Chris
Sent: Thursday, January 8, 2026 12:29 PM
To: Chris <chris@lycon.com>
Hi Chris,
More questions – 1) With Ly-Con porting & polishing of the factory installed Lycoming 0540-J3C5D(235hp) cylinders on the Cessna R182, how much HP increase can be expected? Note: cylinder PN 05K21231
2) Is the rubber crankcase seal available for use on certified airplanes like the Cessna
R182? If so what is the typical cost to cut & install the rubber seal?
Thanks
www.cessnar182.com
Posted: Thu Jan 15, 2026 2:09 am
Scott
Chris
Hi Chris,
Thanks
www.cessnar182.com
