Battery Trickle Chargers
Posted: Tue Nov 25, 2025 11:16 pm
by Cole R182_Retract
For those who use a trickle charger while your plane is hangared, do you use the BatteryMINDer trickle charger? I had an A&P IA tell me that planes with a 28V system generally consume their battery every 2 years. It would be great to get about 5 to 6 years out of a battery. And do you use the Airframe Interface Kit so it can be plugged into the ground power receptacle?
On my previous plane with a 14V system, the Concorde battery would last at least 7 years. The battery used a pigtailed connected to a BatteryMINDer so it could be quickly plugged in and remove without having to remove the battery box cover to expose the positive and negative posts of the battery.
Re: Battery Trickle Chargers
Posted: Thu Nov 27, 2025 5:38 pm
Yes the BatteryMINDer® Model 244CEC2-AA-S5: 24V 4 AMP CONCORDE® Aviation Battery Charger-Maintainer-Desulfator is the charger of choice for our Concorde RG24-16 batteries.
See https://www.batteryminders.com/batterym ... esulfator/ stating"These chargers-maintainers-desulfators are designed for all size and type 24-Volt CONCORDE® Aviation Batteries. If you want the longest possible life and performance from your batteries there is no other product better at doing just this and BatteryMINDer® Guarantees it!" per propaganda on the BatteryMinder site.
The A&P who mentioned replacing 28v system batteries every two years suggests there is battery abuse(i.e. extreme conditions) or systems issues. Our Concorde Rep indicates RG24-16 batteries should remain airworthy(that is pass the capacity test with 85%) for about 5yrs+/- under normal conditions. As a data point our 5 yr old battery just passed the capacity test with 85% results indicating we'll likely need to replace it next year. The R/TR182 Type club YouTube channel Zoom meeting with Concorder earlier this year someone on the call had a 13 year old Concorde battery. So battery care & feeding matters!
For those of us who fly single pilot IFR battery health is of key importance.
Installation of BatteryMINDer® Accessory: BM-AIK2A | AIRFRAME INTERFACE KIT FOR USE WITH FAA-CERTIFIED AIRCRAFThttps://www.batteryminders.com/batterym ... -aircraft/ posted separately. See viewtopic.php?p=514#p514
