Sent: Thursday, January 8, 2026 12:29 PM
To: Chris <chris@lycon.com>
Subject: RE: Reminder - Tuesday 1/6/2026 7PM CST Zoom discussion with Cessna R/TR182 Type Club
Hi Chris,
More questions – 1) With Ly-Con porting & polishing of the factory installed Lycoming 0540-J3C5D(235hp) cylinders on the Cessna R182, how much HP increase can be expected? Note: cylinder PN 05K21231
2) Is the rubber crankcase seal available for use on certified airplanes like the Cessna R182?
If so what is the typical cost to cut & install the rubber seal?
Thanks
scott@cessnar182.com
www.cessnar182.com
Sent: Thursday, January 8, 2026 3:02 PM
To: scott@cessnar182.com
Scott
We’d expect to see 25/30HP increase in the dyno with ported cylinders
And yes, there is an STC on our case o-ring mod…so okay for certified engines. We charge $1278.00 to modify the cases
Chris
Ly-Con Crankcase Seal Article & STC cost; Porting/Polishing results for Lycoming 0540(R/TR182) Engines
- Has thanked: 11 times
- CRANKCASE SEAL.pdf
- (399.15 KiB) Not downloaded yet
