Worn seat rail removed
After watching this rail the last four years I'd had enough of the barely legal oggled out holes for the seat latching pins. See 1) the worn holes, 3) the floor with rail removed, and 2) the removed rail with metal pattern cleco'd into the mounting holes to confirm proper alignment.
New railing was $460 from McFarlane(in stock) - if only the club's 10% discount was in place 3 weeks ago!
Now to drill out and install the new rail. Likely not as easy as it looks!
Re: Worn seat rail removed
McFarlane & FAA reference docs for seat rail replacement attached.
FAA SeatRail doc ce-90-03r2.jpg (201.6 KiB) Viewed 629 times
how-to-install-mcfarlane-seat-rails Page 001.jpg (137.91 KiB) Viewed 629 times
how-to-install-mcfarlane-seat-rails Page 002.jpg (106.59 KiB) Viewed 629 times
