Create list of all Textron Service Docs for your airplane
R/TR182 Service Bulletins & Service Letters listed here
Has thanked: 15 times
The attached is a complete listing Service Bulletins and Service docs applicable from the Textron site for our 1978 R182 as of 6-18-2024. You can generate the same list for your airplane by following the below:
Gather the list of Service Information documents for your airplane at ww2.txtav.com/TechnicalPublications/SI . You will need to create a login first.
That search generates a list of:
All mandatory Airworthiness Directives (ADs)
Recommended Special Airworthiness Information Bulletins — aka Service Bulletins or SAIBs.
Optional, informational and non-applicable service information documents that apply to your airplane.
When you get to the Service Information dropdown menu, how you fill in the fields is critical to get useful results. Fill in those fields as follows:
Select Cessna in the Switch To box
Leave the Search Criteria – Save Searches blank
Select Turboprop/Piston under Model and leave the drop-down box empty
Enter your airplane’s serial number in the Serial Number box
Leave blank the Pub Number, Compliance, Title Description, and Date boxes
Check all boxes in Publication Type
Now select the Search button, then make it a PDF on upper right button.
6-18-2024 All Textron Svc Docs for R18200272.pdf
(93.92 KiB) Downloaded 151 times
