Example ADS-B Performance Report
Discuss panel-mounted avionics, gauges, GPSs, and associated software
Here's what your get back from your ADS-B Performance Report request when the results indicate there are no signal errors:
Dear Aircraft Owner/Operator:
Thank you for your participation in the Federal Aviation Administration’s (FAA) Public ADS-B Performance Reporting System.
Your requested Public ADS-B Performance Report (PAPR) for A1EFE0 (50367740) on 08/08/2025 is attached. All times and dates are expressed in UTC. For more information about this report, please refer to the PAPR User's Guide.
Be advised that flight operations occurring at the fringe of ADS-B ground station coverage can cause intermittent signal losses with aircraft avionics. This condition may generate various false failure indications (red flag for Percent Failure - PF and/or Maximum Consecutive Failure - MCF flag) within a Public ADS-B Performance Report (PAPR). Such failures will vary depending on the duration of the flight in this condition. Please refer to the FAA ADS-B Airspace Webpage for more information or download the FAA ADS-B Coverage Map for use in Google Earth.
If you receive a PAPR with suspected false failure indications, please email 9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov and request that your avionics performance be manually reviewed prior to taking maintenance action. Please attach the PAPR file and include "PAPR Review Request" in the subject line of the reply email to help expedite a response.
Recipients of Performance Reports flagged red for Air-on-Ground issues are advised to contact their repair shop and/or avionics manufacturer(s) for guidance on appropriate corrective action.
Please do not reply to this email; it is a distribution mailbox only.
Flight Standards Service, Aircraft Maintenance Division
https://www.faa.gov/air_traffic/technology/equipadsb/
Have questions? Get answers from our Frequently Asked Questions: https://www.faa.gov/air_traffic/technol ... ources/faq
PAPR_20250808_A1EFE0_596699732 Page 001.jpg (123.88 KiB) Viewed 135 times
PAPR_20250808_A1EFE0_596699732 Page 002.jpg (79.92 KiB) Viewed 135 times
PAPR_20250808_A1EFE0_596699732 Page 003.jpg (83.99 KiB) Viewed 135 times
PAPR_20250808_A1EFE0_596699732 Page 004.jpg (172.79 KiB) Viewed 135 times
PAPR_20250808_A1EFE0_596699732.pdf
(101.79 KiB) Downloaded 63 times
