Electroair Electronic Ignition replacement for 0540-L3C5D Dual magneto
I installed the Electroair dual electronic ignition system in my 1979 TR182 in March of 2023. The engine is the O-540-L3C5D. I am happy with the EA system. I have attached an article that chronicles the installation and initial flight ops. The engine makes more power and uses less fuel than the D3000 dual magneto. The EA system removes the common mode failure associated with the D3000 Mag. I would typically operate the engine as follows: MP 23", RPM 2200, FF 13 gph. With the EA system, MP 23", RPM 2200, FF 11.7 gph. CHT are slightly higher 370-380 F. The airspeed is the same in both cases. I am happy to answer any questions that you may have.
- Electroair Installation in a 1979 Cessna TR182.pdf
- (2.33 MiB) Downloaded 81 times
tdfuller
- Been thanked: 1 time
Re: Electroair Electronic Ignition replacement for 0540-L3C5D Dual magneto
Do you have the turbonormalized induction curve programmed in to the controllers?wlloyd03 wrote: Thu Sep 25, 2025 8:55 pm I installed the Electroair dual electronic ignition system in my 1979 TR182 in March of 2023. The engine is the O-540-L3C5D. I am happy with the EA system. I have attached an article that chronicles the installation and initial flight ops. The engine makes more power and uses less fuel than the D3000 dual magneto. The EA system removes the common mode failure associated with the D3000 Mag. I would typically operate the engine as follows: MP 23", RPM 2200, FF 13 gph. With the EA system, MP 23", RPM 2200, FF 11.7 gph. CHT are slightly higher 370-380 F. The airspeed is the same in both cases. I am happy to answer any questions that you may have.
Electroaire within the last year or so came out with improved curves; the standard curve is the original curve which advances timing two degrees for every one inch drop of manifold pressure below 24 inches, the new so-named "Top Flow" Induction Curve that advances time two-thirds of one degree for every inch of manifold pressure loss below 24 inches, and the turbonormalized curve that does not advance the timing at all.
I had my controllers just sent back a month or so ago to have the "Top Flow" induction curve programmed in my normally aspirated R182; my controllers shipped with the Standard Curve in 2023, but since then, Electroaire has learned a lot more about CHT's etc.
An normally aspirated Lycoming owner could elect to have the controllers programmed with the turbonormalized curve.
Great question:tdfuller wrote: Thu Oct 02, 2025 4:26 amDo you have the turbonormalized induction curve programmed in to the controllers?wlloyd03 wrote: Thu Sep 25, 2025 8:55 pm I installed the Electroair dual electronic ignition system in my 1979 TR182 in March of 2023. The engine is the O-540-L3C5D. I am happy with the EA system. I have attached an article that chronicles the installation and initial flight ops. The engine makes more power and uses less fuel than the D3000 dual magneto. The EA system removes the common mode failure associated with the D3000 Mag. I would typically operate the engine as follows: MP 23", RPM 2200, FF 13 gph. With the EA system, MP 23", RPM 2200, FF 11.7 gph. CHT are slightly higher 370-380 F. The airspeed is the same in both cases. I am happy to answer any questions that you may have.
I tried the full curve and the top flow curve. I found that neither was satisfactory. Both of them allowed the engine to overheat (CHT>380) during ground ops. I did not see any advantage to the curve since I run 23" MP and the advance curve is basically complete at 14 degrees BTDC. My controllers are not programmed with an advance curve. This keeps all of my CHTs <385 F in all phases of flight.
tdfuller
Oh wow! > 380 degrees during ground ops. Thanks for your insights. I am now on the Top Flow Induction curve now and will try that for a year or so and see how that treats my CHTs. I do not have CHTs that high on the ground. The question will be if I get > 400 degree CHTs' while on long flights of > 8,000 MSL which I do not do a ton since most of my flights are in the piedmont and coastal plains of the Carolinas. But typically at least a few times a year I go over the Appalachians or greater than two hours in a flight where staying 8,000+ MSL is common.
