Ly-Con Crankcase Seal Article & STC cost; Porting/Polishing results for Lycoming 0540(R/TR182) Engines
Sent: Thursday, January 8, 2026 12:29 PM
To: Chris <chris@lycon.com>
Subject: RE: Reminder - Tuesday 1/6/2026 7PM CST Zoom discussion with Cessna R/TR182 Type Club
Hi Chris,
More questions – 1) With Ly-Con porting & polishing of the factory installed Lycoming 0540-J3C5D(235hp) cylinders on the Cessna R182, how much HP increase can be expected? Note: cylinder PN 05K21231
2) Is the rubber crankcase seal available for use on certified airplanes like the Cessna R182?
If so what is the typical cost to cut & install the rubber seal?
Thanks
scott@cessnar182.com
www.cessnar182.com
Sent: Thursday, January 8, 2026 3:02 PM
To: scott@cessnar182.com
Scott
We’d expect to see 25/30HP increase in the dyno with ported cylinders
And yes, there is an STC on our case o-ring mod…so okay for certified engines. We charge $1278.00 to modify the cases
Chris
CRANKCASE SEAL Page 001.jpg (210.48 KiB) Viewed 11 times
CRANKCASE SEAL Page 002.jpg (331.85 KiB) Viewed 11 times
CRANKCASE SEAL Page 003.jpg (354.8 KiB) Viewed 11 times
CRANKCASE SEAL Page 004.jpg (239.29 KiB) Viewed 11 times
CRANKCASE SEAL Page 005.jpg (318.13 KiB) Viewed 11 times
CRANKCASE SEAL.pdf
(399.15 KiB) Not downloaded yet
