O & IO540 Engine Oil Dipstick o ring replacement fixed oil leak at oil filler tube
Observed slight oil leak at oil filler on IO540 so replaced the dipstick o ring which seems to have solved the issue. See Parts Manual info and photos attached. Old o ring needed replacement.
- O or IO540 Engine Oil Dipstick o ring info.pdf
- (175.26 KiB) Downloaded 121 times
