electroair Electronic Ignition replacement for 0540-J3C5D Dual magneto
Has thanked: 9 times
Been thanked: 7 times
R182 Owner Todd Fuller advised good results after 1-1/2 years of service with electroair's Electronic Ignition system including easier starts, variable spark ignition benefits, slightly cooler CHTs and no more dual magneto to maintain or worry about.
Installation Manual and Approval docs attached.
IM EA-23000 REV 01_ Page 001.jpg (99.33 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 002.jpg (128.32 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 003.jpg (179.99 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 004.jpg (194.64 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 005.jpg (123.34 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 006.jpg (120.75 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 007.jpg (126.34 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 008.jpg (135.81 KiB) Viewed 3571 times
IM EA-23000 REV 01_ Page 009.jpg (105.49 KiB) Viewed 3570 times
IM EA-23000 REV 01_ Page 010.jpg (109.57 KiB) Viewed 3570 times
IM EIS-61000 REV18 Approved.pdf
(2.42 MiB) Downloaded 269 times
IM EA-26000 Rev01 Approved.pdf
(400.98 KiB) Downloaded 95 times
tdfuller
Been thanked: 1 time
Re: electroair Electronic Ignition replacement for 0540-J3C5D Dual magneto
Post by tdfuller »
Thank you Scott! I will be glad to answer further questions in detail! Since I had my system operational May 2023, since then, Electroair has made two additional improvements. The gears inside the MTH (magneto timing housing) have been improved; some gears showed minor wear and this issue was caught and corrected early. In the same shipment, the controller was returned and another no-cost improvement was made; improving the timing (by software) to ensure CHT's were running cool, and, potentially improve fuel economy. On CHT's, some operators reported having high CHT's before the improvement. I had elevated CHT's but nothing I would say was alarming; perhaps because my baffles and baffle seals are well maintained. However, with the dual EIS and IBBS the spark burns so efficient and hot it is my opinion imperative to have good baffles and baffle seals whereas with the old D mag system it is not as difficult to get away with sub-par maintenance on the baffles/seals. After my system's controller software was modified, since then, I never see a CHT above ~390 even with cowl flaps closed in climb, and usually < 390 regardless of flight parameter.
Thanks for the additional details Todd. We're looking forward to having a Zoom discussion so you
can educate us further on the electroair system.
tdfuller
Post by tdfuller »
Looking forward to it!
andsmi
Post by andsmi »
Todd, I look forward to the Zoom call and learning more about Electroair's changes to your controllers. After sorting out several issues, we're finally using our aircraft, and we are running much hotter than you are. Baffles are 100% new, and we have addressed some possible induction leaks. Much of our original installation had to be reworked, with several parts replaced by Electroair. Did they send you a timing advance curve for the latest setting you received that you can share?
tdfuller
Post by tdfuller »
I just had Electroair do the standard 1 degree timing adjustment that they recommended when I had the MTH sent in to have the gears replaced with upgraded gear/gear teeth, it was easier to go ahead and send in the controller as well per their recommendation to adjust timing one degree to better improve CHT's although I never had major issues with CHT after installation. I assume your baffle *seals* are also well looked at, not just the baffles. Even a small hole the size of an eraser head in the seals can cause CHT's to rise quite a bit. I also use reinforced silicon for my baffle seals.
RussS
Post by RussS »
Just a note of information - on the R182's when the controllers are reprogrammed to 22 degrees BTDC, they are programmed to what Electroair calls the "22 degrees top induction programming" - This changes the BTDC timing, but also changes the advance timing curve. The standard curve starts the advance timing at 24 inches MP, and advances the timing 15 degrees by the time the MP drops to 17 inches. The "top induction" curve also starts advancing the timing at 24 inches MP, but only by 4 degrees when the MP drops to 18 inches. This has been done to alleviate the problem of high CHT's experienced by most R182's.
mrbTR182
Aircraft Type: TR182
Post by mrbTR182 »
Hello, There was a refernce to a zoom call a couple of posts above on this topic. Was it held, was it recorded and might it be available to review?
Thanks
tdfuller
Post by tdfuller »
mrbTR182 wrote: Thu Jan 23, 2025 7:00 pm Hello, There was a refernce to a zoom call a couple of posts above on this topic. Was it held, was it recorded and might it be available to review?
Thanks
viewtopic.php?p=169#p169
Thebigdill
Post by Thebigdill »
I’m about to have one installed. I don’t have an engine monitor so I’m a little nervous. (Doing a panel later so don’t want to install an engine monitor now and rip out later)
Any advice before all of the parts get here and I begin install?
