SEB95-20 Nose gear actuator down lock pin inspection
- Has thanked: 11 times
Important to review/understand the SB to prevent NLG collapse. 2nd attachment is real world example of NLG collapse due to not performing SEB95-20.
- SEB95-20 NoseGear Actuator DownLock Pin Inspection.pdf
- (158.44 KiB) Downloaded 228 times
- CessnaRG NoseGear Collapse Example.pdf
- (2.3 MiB) Downloaded 245 times
Re: SEB95-20 Nose gear actuator down lock pin inspection
Any idea on a shop that’s done this and approximate cost?
In late 2020 Air Repair in Prescott, AZ performed SEB95-20 as part of our prebuy and cost was $1300, which is approximately 10 labor hours. Air Repair's mechanics had maintained R182s so were familiar with this SB, meaning other unfamiliar shops may take longer/cost more.
We borrowed the drill guide tool(PN1290009-3) to avoid the cost of SK210-155(approx.$3000) which kept the cost low by avoiding the cost of the Service Kit. We're working on sourcing of the drill guide or Service Kit for a reasonable cost for type club members.
View SEB95-20 here:
View SEB95-20 here:
A) did you send the part to them to have the mod done?
B) anyone in the Great Lakes are do this?
The shop supplied the new roll pins & downlock pins, and I sent them the borrowed drill tool.
The rolls pins are commodity items and at that time the downlock pins were in stock at Textron and inexpensive.
Any experienced Cessna shop shop be familiar with SEB95-20. I know of an individual mechanic here
in SE WI who is familiar with it as well.
See highlights & comments on p.3. If your airplane has not had SEB95-20 performed then
p.3 is key information. Keeping in mind the late model C210 NLG actuator assemblies
are identical to the R/TR182 - this is confirmed in the Effectivity list on P1&2 of the SB.
- 028tech Nose Gear Spring Guide & Actuator Pin Inspection.pdf
- (232.61 KiB) Downloaded 103 times
- (2.3 MiB) Downloaded 103 times
